So on my first try, after torquing all the beadlock ring bolts down properly, I still got some gap between the ring and the wheel itself. I even used the existing 1/8” poly spacer that came with the wheels, but the ring was touching in some spots and not touching in others. After looking online some, it seems that this isn’t uncommon with thick-walled tires like the MT/R...
Round 2: I order 10 new ring spacers kits (5 wheels x 2 spacers per wheel which should give me ~1/4” - plenty to close the gap). Unlike the old ring spacers, the new kits are quarter-circles rather than a single solid spacer.
Unfortunately, it appears as though the OD of the (four) spacers is slightly larger than the ID of the tire. This is causing 2 issues. First, the bolt holes of the spacer are offset from the holes of the nutserts within the wheels. Pushing some out of the way and hand fitting a bolt in causes bending and buckling of the spacers themselves.
As a result of #1, when I don’t wedge the quarter pieces together, the circumference of the four combined quarter-spacers does not match the wheel, causing one end to overlap the other
I will need to contact Raceline in the AM to see what their suggestion is, but figured I’d pick your brains first.
Seems like I have 3 options:
1) trim the inner edge of the tires to make some room for the spacer
2) trim the outside edge of the spacer to fit inside the gap
3) shim the ring spacer below the edge of the tire
Maybe I need to sit out there and ponder some more, but I think #3 above won’t work since it will not make a seal against the inside face of the wheel, leading to leaks. This leaves me with #1 or #2.
My concern with #1 is obvious - screwing up an expensive new tire. My concern with #2 is that I don’t know if there is enough meat on the edge of the spacer to adequately trim while having enough strength to hold up.
What say ye?
What say ye?
