Random misfire / running rich
98EvaldWrangler
Jefferson, oregon
Hey everyone, I have a 98 tj 4.0 with the 5spd Ax-15 trans. About two months ago I gave it a good bath(flooded it) I sucked i! water then turned it off. Trailered it home drained the oil( mainly water) then ran some oil through it and have done about 4 oil changes since then. It runs really Rich and has random misfires, I’ve changed the plugs twice, wires once and both o2 sensors, the tps, the crank shaft sensor(mopar) the cam shaft sensor, the map, cleaned my throttle body, got the intake manifold glass ball cleaned, replaced all injectors, have good fuel pressure and good compression. No bad noises from the motor just runs like crap, I’ve even replaced the header and the cat. I don’t understand what goin on?? Anyone have suggestions that I can try I’m lost
