SOLD Random TJ Parts
Jamison C
Heil Savvy 🙋‍♂️
Sedona, AZ
Price
Listed
*Updated as of 4/30*
All prices do not include shipping
1). $10 - One functioning window washer pump with grommet.
2). $50 - Extra bearings and shims for Dana 35. These came with my Revolution gears but my installer “didn’t like” Koyo bearings because they set up differently than Timken. Pinion seal, crush sleeve, and pinion nut are in there too. I have no idea which bearings are for what. Tons of shims.
5). $15 - Speedo gear 36-tooth.
Any questions feel free to message me. Thanks for looking!
Id love to have those flare extensions.
Shipped to 35126?
If I put them in a Flat Rate box probably between $7-15 depending on if they fit in a small one or not. I’ll check tomorrow.
The fender flare extensions are much too big for a Small Flat Rate box. Regional Rate boxes or using your own packaging (sometimes gets lucky on weight and dimensions) are your best bets.
Good to know. I have a ton of boxes/packages around the garage so I’m sure one of those will work
Reactions: Fouledplugs
I just need one of your rim's to complete my set. Would you be willing to separate?
I need to update a bunch of this lol. I haven’t even had a chance to list the wheels locally. I’m going to this week and if they don’t sell I’ll keep you in mind
Hi , I'm new to site and jeeps. If possible can you tell me if you have the defroster trim that goes along top of dash? If so, a picture would be great to confirm fit. It's for 2005 Thank you.
Updated 12/11 with new stuff listed and stuff sold taken off of post.
I need a ZIP Code. I’ll look into it a little later this week. Swamped for the next couple of days
*Updated as of 12/13*
1). $200 - Mopar Khaki full door panels. Driver side has the notorious crack in it. Includes door pull.
View attachment 109367View attachment 109368View attachment 109369
2). $200 - Powertrax No-Slip locker for Dana 35. A friend gave it to me after upgrading to a Dana 44 and I never installed. It has about 1000 miles on it and all parts are present. OE 27-spline axles aren’t the strongest. Know the potential risks of installing this in a stock Dana 35.
3). $10 - One functioning window washer pump with grommet.
4). $50 - Extra bearings and shims for Dana 35. These came with my Revolution gears but my installer “didn’t like” Koyo bearings because they set up differently than Timken. Pinion seal, crush sleeve, and pinion nut are in there too. I have no idea which bearings are for what. Tons of shims.
I am putting in a 4.10 and have 35 inch tires. Auto transmission and original 3.07 gears. Any idea what tooth gear I need and is your 36 close? Jeff in Chandler
If you still have the washer pump, I’m interested. How much shipped to 49508?
