Rapid blinker
McSethro
OH
My driver side blinker is rapid, but the bulb does not work when the headlights are on as the marker light. Neither of the side markers on the fenders have bulbs, but everything on the passenger side works. Any ideas?
A fast blinker indicates a bulb is not flashing. Either a bad connection or a burnt out bulb. From the post it sounds like you have several issues to address. Maybe take it to a mechanic. And as Long Rider says, try english next time.
This is why I get my mechanic to do my oil changes, he does a complete check of the vehicle and would have fixed all those lighting issues.
Reactions: Hog
I'm not sure I understand the question either. I know that you NEED bulbs into those side markers, otherwise you're going to get rapid blinking. Put some bulbs in them, and make sure you use the right bulbs (not LEDs).
Replace all missing & burnt out bulbs, if it still blinks fast you probably have a short somewhere.
Sorry for the unclear wording. Both blinkers will flash when they are supposed to. Only the driver side is rapid. when the headlights are on the passenger marker light will come on as it should but the driver side marker does not come on. They are the same bulb, just didnt understand why it wouldnt come on with the markers. Maybe the socket or connection at the socket? I'll get the tester out and do some hunting and report back. Thanks
