Poison Spyder LED marker lights not working
Did you ever find a fix for this because I having the same probl
Yes, I got it figured out...well my friend figured it out and he set up some one-way diodes. Doing that on the red wire so power can only go towards the blinker fixed the problem. I will include a picture I just went out and took. This should get the arrows off the dash. Hope this helps IDK why it has to be so hard I did this exact thing without a diode on my old jeep without any issues.
The circle is the diode under the electrical tape. Which only allows the power to go one way.
So this diode job worked for some time. But now if I don’t have the lights on, both will sides will blink instead of just the side. I just re-wired it without it helping anything.
Any thoughts.
I finally found a solution to have led markers without the green arrows showing up on the dash. The solution to this Green Arrow issue is using a custom LED Harness that allows a 2 wire LED to have a running light and indicator light. Here is a link to the harness I used. Once wired up with a 2 wire LED, I have full functionality without the green arrows showing up on the dash.
I made a video below on how I did it and explained how it works more. Hope this helps let me know if you have any questions.
I used a 3 wire LED light from poison spyder. I have marker and turn signals and required no additional wiring. They aren’t cheap, but it was easy.
@Gollywomper I had a 3 wire, poison spider LED originally, but it caused the green arrow on dash issue. Maybe I had the wrong poison spider LED. Which one did you have? Maybe send a link.
I think it just depends on your Jeep for some reason. My old Jeep didn't have this issue, but my new one did. So I had to find this solution.
