Hey guys! I'd love to get some feedback on a dilemma that I have with my Jeep's steering setup.
TL;DR - I replaced a bad set of TREs with a new Currie 9701 steering kit, not realizing that my knuckles were drilled out to around 5/8" (the Currie bolts are around 1/2" from the looks of it). The result is obvious: some noticeable lateral play when I turn the wheels. My dilemma is this: since the knuckles were already drilled out once, how bad of an idea would it be to have a reputable shop re-drill them to out (to 7/8") so I can fix the lateral play issues with tapered sleeve inserts? (The alternative being a new set of knuckles that will accommodate the smaller Currie links)
Back story...
I bought an '05 Rubi that I knew had some wonky steering issues. Not being afraid to turn a wrench and knowing just enough about the basics of Jeep steering systems, I quickly identified the root cause to be the TREs on the aftermarket (Moog) setup that was on there when I bought it.
I drove it down south (slowly) to a 4x4 parts store in Tacoma, WA to see if they sold and compatible TRE replacements. The guys at the shop took a long (~10 minutes) at my setup and told me what I already knew about the problem. They wound up talking me into a Currie 9701 + a steering stabilizer.
After getting the new system installed and doing an alignment, everything seemed better - but not perfect. I took it for several test drives that evening, gradually driving it more aggressively to test the new system and get a feel for the change in steering characteristics. It seemed safer than the previous setup.
It wasn't until the next afternoon that I realized there were potentially serious problems. My 20+ mile drive to work was slow that morning (traffic from hell). On my commute home, traffic was moderate - yet moving at 60-70mph. As I'm crossing the bridge on Interstate 90 (connecting Bellevue, WA with Mercer Island), there is a slight downhill grade and right dogleg curve. I start to turn with my mind on autopilot - negotiating the curve at ~60mph. My front wheels all the sudden jerk my vehicle towards the lane to my right, out of nowhere. Autopilot turns off in my head and I had to really work to get my vehicle under control - slowing down to ~35mph after all was said and done. I realize at this point that there is a problem.
Fast-forward 40 or minutes later, I pull into the driveway and get my wife to come out so she can shake the steering wheel while I look at the steering system. Right away, I see the lateral play of the TRE bolts and a destroyed rubber boot on the passenger side where the drag link connects.
To make matters worse, a week later I replaced the pitman arm with a new RE pitman arm that I ordered. In doing so, I had to drop the steering kit to remove the old arm and get the new one installed. I then realized that the castle nut on the drag link bolt is SPINNING and not coming off! So now I probably need to get that guy replaced as well
This Currie kit has been a curse since day #1. The thing that REALLY gets me fired up is the shop guy "veteran" that has installed hundreds of the Currie systems in the last 15+ yrs or so they claim, didn't notice that the castle nuts on my old kit were MUCH larger (27mm) than the castle nuts that come with the Currie kit (19mm). I would think that should have been a red flag that the Currie system wasn't going to be a perfect fit.
Back story...
