As the title says I’m re-gearing my 2004 TJ Rubicon to revolution gear 5.38 master rebuild kit. I’ve taken the front axle apart and notice that the original pinion has an oil slinger and the new master kit does not have the oil slinger. I would normally just reuse the old one but I noticed from @Jerry Bransford post about re-gearing his same year rubicon to 5.38 he did not use the oil slinger. Is there a reason for this? Should I refrain from using it? Any help is appreciated!
