This may have been mentioned before, but I've seen quite a few posts that require reading the codes from the Jeep. I found this cheap Bluetooth OBDII interface that works great for reading and clearing codes on my TJ.
Foseal Bluetooth OBD2 OBD Scanner Check Engine Light OBDii Bluetooth Car Diagnostic Scan Tool for Android Devices https://www.amazon.com/dp/B00T5G53ZM/?tag=wranglerorg-20
This one is less than $13 and can do a lot of the same things as the expensive scanners. This one only works with Android devices though. You'll also need the Torque app for about $5. The amount of information you can pull from the ECU is great for troubleshooting or even just to see the magic in real time that goes on inside the computer. Great tools to have for less than $20.
There are some for iPhones but I haven't tested any of them. This one has good reviews on Amazon.
Car WIFI OBD 2 OBD2 OBDII Scan Tool Foseal Scanner Adapter Check Engine Light Diagnostic Tool for iOS & Android https://www.amazon.com/dp/B00W0SDLRY/?tag=wranglerorg-20
Sent from my Nexus 7 using Tapatalk
