Been chasing a "clunk" for some time now. It only happens the first time braking after changing direction from forward<->reverse. Getting out of parking spaces is a great example of the conditions for the clunk. Threw a couple of GoPros under the chassis and saw that the brake caliper jumps right when the "clunk" happens (see video below). Even the dust shield and the parking brake cable moves, but everything else is smooth. The caliper mounting bolts are properly torqued. Took off the wheel and rotor and there is a little bit of rotational play in the axle (not side-to-side though). With enough force, I can get a soft "clunk".
Any suggestions for what to try next, or educated guesses on the cause/solution?
Here's some background on the Jeep:
- 2005 Jeep Wrangler Unlimited (LJ)
- 65,000 miles
- Bought last fall
- Pristine frame, lived in SoCal it's entire life (kept in a garage for the last 5 years)
- No signs of previous off roading or abuse
- Shocks
- Rear upper and lower control arms
- Sway bar links
- Drag link
- Tie rod
- Stabilizer
- Track bar
- Sway bar bushings
- Torque settings on the caliper mounting bolts
