I was IMMENSELY frustrated with how stupid it was to remove the rear fender flares. As I’m sure y’all know, only the front 2 and rear 1 are actually bolts that thread into threaded inserts, the rest are screws that screw into stupid Flat plastic “nuts” that spin when you try to unscrew the screws. So you have to remove the inner fender well to remove the flares. Dumb. As well, the rear bolt on both sides was corroded into the threaded insert and broke when I tried to unscrew them.
Once I had everything apart, I drilled every hole out to 19/64” and installed 5mm threaded inserts into every hole. Now, the flares will be mounted with zero of those screws and all 5mm X 16mm bolts I got from NAPA. WAY WAY BETTER.
The 1st photo shows the first 2 threaded inserts installed, with the old screw holes also visible. The 2nd photo is obviously a close up of one of the threaded inserts installed.
