Can removing and reinstalling auto transmission possibly disturb the engine rear main seal? Seems the seal has started dripping slightly since this event.
The exhaust routing makes the job a pain in the tail on the last year tjs get a one piece oil pan gasket when you do it and look if there is anything in your oil pan bottom when you have it out
Coincidence. It isn't possible to move the end of the crank enough to disturb the seal. The first thing that helps are the alignment dowels. They engage the case before the pilot on the converter slips in. Even if it were possible to have the full weight of the trans trying to lever the end of the crank and move it, it is supported by the main bearings. If you were to find a way to move it far enough to mess up the seal, you would have at least wiped out the last bearing and likely more.Can removing and reinstalling auto transmission possibly disturb the engine rear main seal? Seems the seal has started dripping slightly since this event.
Exactly what engine oil are you using and is it a synthetic or conventional?
ConventionalExactly what engine oil are you using and is it a synthetic or conventional?
I got lazy and cut the exhaust just before the transmission crossmember, and used a band clamp to put it back together. No problems so far.Thanks for the heads up. Have a great Xmas.
Jack
