Several months back I replaced my motor mounts with Brown Dog mounts. A few weeks after I started having a rear main seal leak. I took it to the local mechanic and he did the replacement. Well, it started leaking again immediately. Took it back and he replaced it again. That lasted about a day and it leaked again. So now after being replaced a third time it's again leaking.
My question is could it stem from replacing the motor mounts? The install was kind of a bugger and it took using ratchet straps to get the motor in position for the bolts to line up. Could things now be out of whack which is causing this?
