I have a little vibration around 40-50 mph and working to iron it out on a nice day. I have a stock driveshaft with a 1.5" TC drop and 3.5" lift. I have double-adjustable rear upper control arms so I'm confident I can set the pinion angle correctly, I just want to ensure I'm measuring from the right spot.
In the pictures below, I've looked at measuring from the top of the harmonic balancer and got 8.1*, then from the side and got 8.8*. (a) which one is correct to measure?
I figured the top was more accurate than the side and got the rears as close as I could. I measured them at the circles next to the back of the pumpkin. (I found this to be commonly referenced and feel confident about this. This is what I can adjust...by the TC case doesn't seem to adjust.
I've also included pictures of the entire setup in case I'm totally wrong.
EDIT: Some of the pictures are sorta dark. For whichever is unclear, I'm going to reshoot for clarity.
