First of all let me start by extending a general thank you greeting to all the members of the TJ forum.
I'm in the process of reclaiming/fixing a 2002 Jeep Wrangler X and this forum has been the most helpful, specially with steering issues.
thank you all
Now for my first post...
I'm the the process of replacing the rear lower control arms (they were shot, loose!!) and I noticed the rear sway bar end links were wobbly, so I'm replacing those also.
about 2 weeks ago I replaced the rear sway bar bushings (did the front ones too)...
I notice that without the end links attached, it is very easy to move the rear sway bar up and down, it doesn't seem to be any friction from the new bushings.
If I remember correctly, the front one has a lot of friction from the bushings...
is this normal? did I use the wrong bushings ? they went in tight.
I used the MOOG K3160 bushings for the rear.
Thank you
4 inch lift
4.56 gears
32 inch tires
thank you all
Thank you
4 inch lift
4.56 gears
32 inch tires
