The TJ's coil spring suspension really demands that both its rear and front antiswaybars be present and connected. Coil springs are not stable in any direction.Did you feel any significant loss in tracking or driving stability? I just pulled my factory axle and put in an 8.8 that didn't come with a sway bar mounts. I'll know in a day or two about adverse effects but figured I'll ask anyways.
Even though I'm running Currie's Antirock up front for rock crawling, I keep my rear antiswaybar installed and connected. The suspension just works better to keep the Jeep more stable and under control when on especially difficult trails. Removing or disconnecting the rear antiswaybar does not increase that axle's usable flex.
It was very noticeable to myself as well as 3 Boy Scouts I was hauling back from the desert after one of my two rear antiswaybar links broke which completely disables the entire rear antiswaybar. After noticing it while driving, I was surprised to hear one of them comment he didn't like how the rear of the TJ was suddenly swaying more on the curving mountain roads we were taking home. I didn't delay fixing it, it was noticeable enough on my local mountain roads that I didn't like it. It'd be no big deal on an older Jeep that has leaf springs but it's a much bigger deal when you have coil springs like our TJs do.Sigh. I guess I'll finish the set up and see about adverse effects. If it's noticeable I guess I can weld on the sway brackets while sitting at ride height.
