Most are glued, lots of choices. I actually used a double sided tape made for glass and trim.Since we’re on the topic. What keeps the plastic trim on the bottom of the glass from coming off?
The top a just picked up seems to be pressure fit. But otherwise can be easily removed and put back on.
i recently replaced all the weatherstripping in the rear of my tj, the glass to top, the glass to tailgate, and tailgate to tub. i can see daylight in both lower corners of the tailgate/tub, and rain pours in through the top of the glass at the hard top and runs down the inside face of the glass. it also seems like my glass is set too high because the tailgate almost sits under the strip its supposed to close against, sealing and securing the glass (which will pop out at the lower corners after i open and close the doors.
is there any adjustment for the glass? i loosened both hinges and tried, but it appears that there is no room to move of shift the glass in any direction.
i find it hard to believe brand new weatherstripping is bad, but holy hell does the water pour in worse than ever.
any ideas on any fixes anyone has come across? i hate to add gasker/sealing material that wasn't there originally so i'm open to any suggestions anyone might have. thanks in advance for any info!
yeah, i had removed the struts when loosening the hinge bolts and had someone push down on the hinge from above while i tightened, i was able to get it slightly lower but not much. i just can't understand why the old weatherstrip barely leaked, while the new weatherstrip...doesn't even touch the glass, i mean barely. i'd need to almost pull the strip off the little leg it slides onto in order for the glass to compress it once closed. makes me think i installed the glass back wrong or proud of the top somehow, which seems impossible.
i didn't add the bulb like you show (popular mod i know) but added this instead, which tightened things up. the difference in closing the tailgate with and without it is significant, even though it doesn't seem like much
https://www.amazon.com/gp/product/B07DGFMZJF/?tag=wranglerorg-20
i bought some black stick-on bulb type foam that i'll fill the lower corners with where the tailgate meets the tub.
thanks for the reply. i'll post pics and results from all this to help others in the future
frank, i replaced that seal already, i don't have too much of a problem with that....at the moment but thanks for the link.I just bought the entire piece at the bottom of the glass from allstate4wd.com.
Did you end up using the oem seal? and if so did it fix it? im having the same issue with my seal from extreme terrain and id love to know if i need to order from mopar or the allstate4wd.frank, i replaced that seal already, i don't have too much of a problem with that....at the moment but thanks for the link.
