This thread gives all the P/N for the mopar parts. I believe as far as the cooling system goes it’s best to stick with OEM
https://wranglertjforum.com/threads/jeep-wrangler-tj-cooling-system-overhaul-faq.3397/
X2
However, the Hayden fan clutch you see listed on that page for your TJ is a very reputable replacement. Cheaper than OE Mopar, and I've never heard of anyone having an issue with one, so I recommend it personally!
Fwiw, I purchased an oem and Hayden fan clutch. I compared the two and they were visually identical. Every mark on the castings were identical. I surmise they are made in the same factory.
Sent from my SAMSUNG-SM-G930A using Tapatalk
My first replacement was a HD clutch. It worked fine, but made the fan incredibly noisy all the time, and I havr found that a non-hd fan cools absolutely just as well. When temps get high enough the oem fan locks and is just as noisy as an hd clutch, but the rest of the time it is much quieter and the Jeep just feels smoother since it isn't working the fan so hard. The hd fan basically just stays engaged all the time. I put the non-hd fan in just before running the Jeep hard across the country and through the mountains. And, I was watching the temps via an OBD reader rather than just the gauge and the Jeep did just fine. Just for another data point, the water pump, radiator and t-stat were all about a year old. So, all relatively good fresh equipment.
Sent from my LGLS990 using Tapatalk
I couldn't really remember, but I was pretty sure that I got it from Summit Racing. I just checked their site and it looks like they have a few now.Where did you get the not-HD fan clutch ? I recently bought one from the Chrysler dealer and it's HD and really annoys me. I'd like to go back to a not-HD clutch. I know I'm resurrecting an old thread, but by now you should also know if whatever you bought is holding up!
I went through this last year too. Here is a thread that I started that has some good discussion in it: https://wranglertjforum.com/threads/fan-clutch-question.18422/#post-299797Where did you get the not-HD fan clutch ? I recently bought one from the Chrysler dealer and it's HD and really annoys me. I'd like to go back to a not-HD clutch. I know I'm resurrecting an old thread, but by now you should also know if whatever you bought is holding up!
This works for later model tjs, right? It seems from what I’ve seen the 2000-2006 models need a different one than the earlier models, I haven’t been able to find any that aren’t HD except thisI couldn't really remember, but I was pretty sure that I got it from Summit Racing. I just checked their site and it looks like they have a few now.
This one specifically states that it is standard duty:
https://www.summitracing.com/parts/fss-36980/year/2005/make/jeep/model/wrangler
Good luck!
My 2000 uses a hayden 2771. Screw on.This works for later model tjs, right? It seems from what I’ve seen the 2000-2006 models need a different one than the earlier models, I haven’t been able to find any that aren’t HD except this
I saw that one but was worried it would be loud since it is a heavy duty, I’m trying to keep fan noise down and don’t live anywhere hot so I don’t think I need an HD one. Can’t find any non-HD ones however so I might just buy that one
It does say hd at the top but if you read farther down it says its actually a regular duty. I believe it's been confirmed that the 2771 is regular duty. I haven't noticed any extra fan noise.I saw that one but was worried it would be loud since it is a heavy duty, I’m trying to keep fan noise down and don’t live anywhere hot so I don’t think I need an HD one. Can’t find any non-HD ones however so I might just buy that one
Great, I’ll give it a shot. I don’t have any overheating issues or anything now but my fan is really loud so I’m hoping this will help, my fan won’t move at all when I spin it by hand so I think my clutch might be worn outIt does say hd at the top but if you read farther down it says its actually a regular duty. I believe it's been confirmed that the 2771 is regular duty. I haven't noticed any extra fan noise.
I’ve ignored it until now because I heard tjs had extremely loud fans, but my friend with a tj said his is a lot quieter so I’m hoping this will fix itSounds like the clutch is seized, a new one will make a huge difference, very quiet.
