In the midst of doing a frame replacement my '02 (previously posted on this).
We're at the point where the tub is 'disconnected' from the frame and motor/trans. Basically, ready to go.
We do not have a lift. I've searched around, but haven't found much. Plan is to lift the tub high enough that we can roll the chassis out and then roll the new frame (once we swap the engine / axles over to the new one) back in underneath the tub.
It seems remarkably difficult to do this! We're considering welding together a bracket that will attach to the torque boxes and extend down to floor jacks on each side, so we can lift the tub off and then slide some long 4x4 beams underneath it and support it that way (basically building a stand from wood underneath the tub). I think this will work but... man it's like half the entire project.
Side question - what's a good OE-equivalent bushing set to replace all the bushings while doing the swap? Prothane seems reasonably priced. Don't need anything fancy, not doing a lift just want to replace the worn bushings.
