Bracket: https://www.barnes4wd.com/Jeep-TJ-LJ-MJ-XJ-and-ZJ-Front-Axle-Track-Bar-Bracket_p_818.html
Replaced my wallowed out front axle trackbar bracket on my Dana 30 as I presume it was the cause of my wobble @ ~45mph with a barnes 4wd bracket, got it all welded up only to find the bolt that fits the bracket perfectly(7/16) is too big for the trackbar.
The trackbar takes an m10 which is free to move around in the hole on the bracket, it seems fine for now wobble eliminated, I got it well and torqued down since I customized to bracket to accept a wrench on the back.
I’m just wondering if the factory bracket hole is slightly bigger than the stock trackbar?
Should I worry about the play wallowing out the hole?
