Im starting to get a little bit of noise from the front end when coming to stop on the TJ, I just spent a few hours re torquing everything in the entire suspension to factory specs, nothing was loose anywhere.
I just recently re did the u joints on both driveshafts and looking at the condition of those when I removed them, I am figuring the front axle u-joints is probably whats causing the noise and wheel bearings could probably stand to be swapped for new ones also.
Does anyone recommend a particular brand of u-joints and front hubs ?
(From my research it looks like I cant just change the wheel bearings I have to replace the full hubs, is that correct ? )
Im not looking for anything to be upgraded and cost a fortune just inline with what the OEM standards are
The jeep has 138K miles on it and from the looks of it the u joints up front look to be the original ones on there
thanks
thanks
