Jod0001
Same problem blower motor not coming on at all. I replaced the fan speed switch, hard wired it because the pigtail was melted, replaced resistor and blower motor relay. Checked fuse number 8 under the dash, not blown. Pulled the blower motor tested it by using alligator clips and the battery, it kicked on. My next step is to check the wiring harness to see if I’m getting power to the blower motor but I figured it would save time just to replace it or them. I’m not sure how many wiring harnesses tie in together but I figured save time testing them and just replace it. I am not sure where to start on replacing it though. AND before I do that I just want to make sure I’m not missing something obvious.
