A super super cheap Dana 35 with 4.10 gears popped up on FB Marketplace just as I was considering a gear swap for my 31-32" tire swap (I've got 3.07 gears!). I'm a sucker for pain, so I snagged it. Concerning the yoke/driveshaft, I'd rather not have to pull the yoke on the replacement driveshaft. Am I likely to run into driveshaft balance issues using my current shaft and the "new" yoke? Would replacing u-joints while I'm at it help (Spicer's are super cheap on RockAuto)? Or should I just go for it, and if I get some vibes flip it 180 degrees and see if that helps? Thanks for any advice, y'all.
Side note, I'm doing the front axle gears and adding a locker, since I have to replace the carrier anyway. I know it's a lot of work to still be on a Dana 35/30 combo, but I like wrenching and I like keeping original equipment going (except for 3.07 gears, seems they're just unsuited for this vehicle!)
