jtmoney065 Member Joined Nov 30, 2016 Messages 28 Location Davenport, IA Feb 16, 2017 #1 Anybody know what size and type of nut and bolt I need to replace my cam bolts. I am putting on adjustable control arms so i won't need the cam bolts anymore. Sent from my iPhone using Tapatalk
PStov98TJ TJ Enthusiast Joined Nov 9, 2015 Messages 554 Location Mississippi Feb 16, 2017 #2 Just leave them in. They shouldn't hurt anything, and it gives you more adjustment.
OP jtmoney065 Member Joined Nov 30, 2016 Messages 28 Location Davenport, IA Feb 16, 2017 #3 I'm going to have to cut them I think. I can't get the lower bolts out. Sent from my iPhone using Tapatalk
PStov98TJ TJ Enthusiast Joined Nov 9, 2015 Messages 554 Location Mississippi Feb 16, 2017 #4 Quick google search says stock is 14mm, but 9/16's will work as well
PStov98TJ TJ Enthusiast Joined Nov 9, 2015 Messages 554 Location Mississippi Feb 16, 2017 #5 Just make sure you get some good Grade 8 hardware, get it good and tight, and call it kosher.
OP jtmoney065 Member Joined Nov 30, 2016 Messages 28 Location Davenport, IA Feb 16, 2017 #6 I did see 14mm but I wasn't sure. Sent from my iPhone using Tapatalk Reactions: PStov98TJ
