9 98tj_Ben New Member Joined Mar 20, 2023 Messages 2 Location West Virginia Mar 20, 2023 #1 When I am in reverse there is a loud clicking happening and I'm not sure where its coming from, it goes in and out of reverse just fine but this noise only sounds when moving backwards in reverse. Anyone know the possible problems?
macleanflood I break sh!t Supporting Member Joined Jul 24, 2021 Messages 4,032 Location Fall Creek, OR Mar 20, 2023 #2 AX-5 in a 2.5 or AX-15 with a 4.0. Probably just a chipped gear or worn bearing. What fluid are you running and have you drained it and checked for glitter? MT-90 is the fluid of choice...might solve the issue. Or is it an automatic? So many choices...we need more clues! -Mac Reactions: sideproject
OP 9 98tj_Ben New Member Joined Mar 20, 2023 Messages 2 Location West Virginia Mar 21, 2023 #3 macleanflood said: AX-5 in a 2.5 or AX-15 with a 4.0. Probably just a chipped gear or worn bearing. What fluid are you running and have you drained it and checked for glitter? MT-90 is the fluid of choice...might solve the issue. Or is it an automatic? So many choices...we need more clues! -Mac Click to expand... It’s a 4.0, and is manual, I have not checked any fluid in a couple months.
