So I did an axle swap to 04 rubicon axles this weekend and when I went to put in the American made revolution shafts for the 03-06 rubicon. The rears went in without a hitch after I removed the old race but for some reason the caps on the u joints are hitting the bolts that connect the hub to the knuckle. Has this happened to anyone else or does anyone have a solution for this? @Chris did this happen to you ever when you got your set? I have them past the seal and they are seated all the way . Any advice would be appreciated before I contact revolution about the issue. I have attached some pictures
