RHD Steering Upgrade
I'm still researching i know the crown product will work and I went and look at it but for my jeep with 5-inch lift and 35 tires it won't last long I like to know if anybody tries the synergy for RHD
Have you done this yourself or know someone who has? looking to upgrade my steering and heard very good things about the synergy kit.. only problem... my RHD jeep o_O
Seen it done a few times, been trying to find a photo. No idea on clearances or anything however.
I’m in the process of replacing mine (bit wobbly and needs tightening up).
If you want just like for like, I got a RHD drag link and Track Bar from quadratec delivered here in NZ.
it’s the Crown brand (not sure how good they are but not much else out there)
For tie rods you can use lhd ones as they fit too. Same with the steering stabilizer
Cheers
how did you like your kit?
I got it replaced today i need to send it to alignment shop to see what they can do, still need to get the bracket for Stabilizer as well but i guess you can can used synergy LHD for RHD will see after alignment and test drive
synergy did not work jeep has a very bad dead wobble and could not get the alignment done so put the old stuff back and ordering the different stuff I will keep you guys posted, thanks amazon prime for sponsoring this project :D:D:D:D:D:D:D:D:D:D:D
I ended up building my own heim crossover setup a slight wobble at 35 occasionally from what I assume is the tie rod rolling but idk. Beefy and solid. Gotta relocate the trackbar to get the angles matching that also might help the wobble. Clearances are okay for now we will see when I add hydro assist here soon
Hey guys
after a long challenging upgrade end but with company name iron rock offroad which offer over knuckle kit with all heavy-duty Heim joint.I will post some pictures soon
Hey guys
So I have a right hand drive from Japan. I’ve wrestled with a few right hand drive issues over the last few years. I got a right hand drive ZJ drag link and track bar since they are solid (not hollow like the TJ) and come from a v8 vehicle. I’ve never had an issue but I also don’t know any better as it’s all I’ve ever run. But it’s been great on and off road.
Hey guys so im actually running into this problem now with my 06 RHD. I can use some advice on what i can do for my car since RHD is limited. In the pic you can see that my stabilizer is rubbing and actually dented touching the drag link. Did a 2.5 inch lift on the car all rancho and cant find a unanimous answer as to why my cars steering looks like this
Back
Top
