It’s warm out and I decided it was a good afternoon for some beer and a little wrenching. Was overhauling the cooling system and noticed what looks like a rivet in the corner of one of the fan blades. Is this a counter weight or what?
Nope, not a counter weight, that is a balance weight.It’s warm out and I decided it was a good afternoon for some beer and a little wrenching. Was overhauling the cooling system and noticed what looks like a rivet in the corner of one of the fan blades. Is this a counter weight or what?
That’s essentially what I meant. Just wanted to be sure the p/o hadn’t rigged up some hoopty shit. Thanks. Back to the beer and installing the new clutch and water pump.Nope, not a counter weight, that is a balance weight.
Been there, done that. A dirty paper towel that is laying around from your last project makes a good soaker upper under said electrical tape.My band aid is electrical tape.
I wanted to like this but that didn't seem right. If you didn't get blood on it you didn't fix it.Ok the water pump gasket that’s been seated since 2004 is a bitch. Scraping it caught my finger on an unknown metal object. Wiped it on a coolant soaked rag (a 1st aid method approved by my wife of course ) and moved on. That is all
@Chris sorry for turning this in to a cross post between my question and something that belongs in the “what have you done to your TJ (Err LJ) today” thread
On another note, I flushed the engine multiple times until what came out of the drain petcock was clear but when I removed the old H2O pump there was a plentiful amount of old, orangey/brown coolant in there. A lot fell to the ground but not all. Should I be worried about this anymore so than just soaking up what the block with a rag?
Dripped blood on the tools and garage floor before wiping on the aforementioned ragI wanted to like this but that didn't seem right. If you didn't get blood on it you didn't fix it.
"Don't kill 'im. If ya kill 'im, he won't learn nothin!"Last time I cut myself is when my Corvette rear leaf spring broke loose splitting my thumb....you could see the blood pooling around the thumb in the glove. But luckily I was on the front side of the rear diff as it sent the bottle jack holding the spring up at a high rate of speed from the ps rear wheel lodging it into the DS rear wheel. I know...stupid of me and If I was on the back side of the diff I would not be here posting.
