Have purchased my first TJ last September and failed to do anti rust before winter really hit, I have a few rust spots that are starting to appear on the rocker panels. No holes yet, just rusted metal + bubbled up paint.
Now the plan:
My bigger confusion is to how to install the said diamond plates on the rocker panels? I understand it's mostly done with rivets - however I live in Canada (Quebec) so very harsh environment and lots of salt during winters. I would prefer avoiding making holes in the body for them not to start rusting next winter. Is there a way to simply use automotive adhesive to stick them on? If not, how would you go about securing the holes you've drilled in the body for them not to rust?
All and any help is appreciated!!
Thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Now the plan:
- Sand / grind all the rust down
- Paint the treated areas with POR15
- Apply a layer of Bondo on top
- Spray a coat of bedliner (or rock guard?) on top of the bondo
- Paint diamond plates
- Install the diamond plates.
Thanks in advance
