I've got an '05 TJ that is giving rough shifts into second (which is understand is common) and has recently started giving rough shifts into third. It shifts smoothly if I double clutch it or if I move the shifter slowly as I upshift. I changed the oil to Royal Purple Synchromesh yesterday and it took it for a drive and I still have the same issue and the temperature was +5C. Sometimes the rough shifts are even a slight grinding. I should also mention that this keep only has 62,000km (about 38,000 miles).
Does anybody have an idea of what might be going on here?
