defenderu TJ Enthusiast Joined Apr 8, 2021 Messages 271 Location Chicago Jun 8, 2021 #1 I’ll assume I was supposed to leave these in when putting my lift on? Just finished the lift cleaning up the garage and came across these. Crap.
06lj TJ Addict Supporting Member Joined Jul 14, 2018 Messages 1,720 Location East Texas Jun 8, 2021 #2 What about them? If you need new ones they have them on Amazon.
OP defenderu TJ Enthusiast Joined Apr 8, 2021 Messages 271 Location Chicago Jun 8, 2021 #3 06lj said: What about them? If you need new ones they have them on Amazon. Click to expand... i left them off during my install. Are they necessary? What are they called?
joelachr TJ Enthusiast Supporting Member Joined Dec 13, 2018 Messages 343 Location Michigan Jun 8, 2021 #4 defenderu said: i left them off during my install. Are they necessary? What are they called? Click to expand... Spring isolators.
06lj TJ Addict Supporting Member Joined Jul 14, 2018 Messages 1,720 Location East Texas Jun 8, 2021 #5 They are called spring isolators. Running without them will cause wear and noise. As easy as the rear springs are to pull I'd put them back in. Reactions: Irun
OP defenderu TJ Enthusiast Joined Apr 8, 2021 Messages 271 Location Chicago Jun 8, 2021 #6 06lj said: They are called spring isolators. Running without them will cause wear and noise. As easy as the rear springs are to pull I'd put them back in. Click to expand... ok will do. Thanks for all your help!!! Reactions: Irun and 06lj
