I'm adding up costs for an eventual upgrade to 35's. Checking out Revolution gear and axles website and started adding things to the cart.
US made front axle kit $1033.99
US made rear axle kit $604
Jeep gear package kit $631
2x eaton Dana 44 e-locker $2145.08
Labor to install gears $1200?
Total is about $5,600
Decided to go look at Currie's page
High pinion front Dana 44 w/e-locker $5328
Rear Dana 60 w/e-locker $5495
Total $10,823
But, I can sell the stock rubi axles and pumps. I've seen them go for about $3500-4000.
New total after axle's sold. $6,823 for the Currie axle's
I like the Currie's because you get the front high pinion, thicker axle tubes, better pinion angles, and I can install them in my driveway vs sending it to a shop to get the gears installed. I understand that both options weak points are the ball joints but I don't plan on going bigger then 35's (famous last words).
So which do you pick and why. Is the Currie axle option worth the extra 1,200? I have about 102k miles on my LJR for reference. I know you can probably do better price wise with other companies so show me how you'd spend the money. In both cases the requirements were 4.88 gears (6 speed), new shafts, and e-lockers.
Total $10,823
