Rubicrawler for $1400
I have the opportunity to purchase a used (apx 15k miles) Rubicrawler from the second owner. It’ll come with the 42RLE it’s attached to.
$1400
I have the 241 installed but have yet to wheel it.
Looking for opinions on how “worth it” the Rubicrawler is
TIA
For a 231, I wouldn't add a RC since the 7.44:1 gearing is silly and you'd already have 2.71:1
For a 241, I wouldn't add a RC for anything other than the 2.72:1 to go faster in trails since 10.88 is silly
$1400 for a 42RLE and RC is a no brainer imo, but I'm a bit biased since I have that setup with a 241 and like it. The Atlas would be even better, but that's more of a dream at this point.
Reactions: Weasellee
Out west in non technical wheeling, I've found the 4:1 241 gearbox to be OK for stretches in 5th gear where you want to do ~20mph between lower speed obstacles. Eventually you'll just want to stop and switch to 4Hi though. Would 2.72:1 change that for me? Probably not.
It changed things for me, but it's not worth comparing since the RC doesn't work with your manual. It replaces the tail housing of the 42RLE.
This is the type of opinions I’m looking for. My thoughts are I would use the 2.72-1 pretty often for the trails I’m on. The 4-1 for the rocks and technical stuff.
It seems the 7.44-1 is just too low?? For rocks??
I’m going to buy it but not sure if I’ll install it before running the 241 without it for a bit.
$1400 is a good price
There are no indicators that you are delivering too much torque to the axles. The chassis doesn't torque over, the engine doesn't bog a little, nothing to tell you to back out of it before you break something. We've warned folks many times in JV to stay out of low low and yet they persist. Then they snivel about how much stuff they break. If you aren't going to use it on rocks, then where?
This is the answer I’m looking for.
$1400
TIA
If you don't want it tell me where I can buy it.
Anyone who tells you the Rubicrawler isn't useful has never used one on rocks.
In low-low any downhill descent is crept down without brakes, perhaps even needing a touch of throttle. Coming off ledges slowly decreases the body roll or bumper grind.
In low-low any technical obstacle becomes a walk in the park. Control is next level, allowing for precise tire placement and traction increases exponentially.
In a Rubicon, sometimes 4:1 is too low, now you have 2.72:1 as an option.
Using it requires some awareness so as to not get bound up, as a practice I don't use it and a locker at the same time. Also, shift to neutral when you want to stop moving because it will power through brakes.
If you like fire roads and mud, its not for you. AdvanceAdapters was super to work with for parts and support. I bought mine second hand but never installed for 1600 a couple years ago.
I bought this and it’s getting installed in my good friend Dave’s TJ with a 231. AA has been great for parts. It’s installed but while the crossmemebr was down he decided to move forward with a custom crossmember that separates it from the skid plate. We will be wheeling it soon. 🇺🇸
