A local one in CO sold in parts and pieces for around $1600...well...$#!+.
I still can't believe that. Everyone on that for sale post thought the dude was nuts for listing it that high. Lo and behold, someone bought it.A local one in CO sold in parts and pieces for around $1600...
It is a lot of money for something that may not be 100% serviceable. Atlas or 300 will have plenty of parts available for a long time.
And he wanted me to rebuild it for him...but I just can't take in a box of parts.A local one in CO sold in parts and pieces for around $1600...
The JK version would work, but it doesn't have a speed sensor. The PCM would be unhappy about that. You could machine an external tone ring and sensor, but that's a lot of work.how different is the JK 241? Are parts interchangeable enough that you could build a complete one with a minimal amount of TJ specific parts?
I offered him what I thought was good money for it and he said he had to get at least $1500. Hell no, no way for a basket case.I still can't believe that. Everyone on that for sale post thought the dude was nuts for listing it that high. Lo and behold, someone bought it.
I was going to mention that you see them pop up on car-part.com here in pieces for a lot of money. A shop locally just rebuilt one that was cracked from a front driveshaft cracking the case.A local one in CO sold in parts and pieces for around $1600...
I have a buddy looking into this too. I know they don't have the speedo. He is thinking about trying this or something similar because the jk cases are typically mich cheaper around here. Still researching that option though. It claims to work by sending a vss signal so maybe it would jive with the pcm?
https://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=837/mode=prod/prd837.htm
Anyone know someone who has done this?
His is a 99 and a manual. He drove around with the speedo disconnected as a test. It just didn't like wide open throttle. It would drive around fine otherwise which maybe it would work on older tjs?I haven't tried it but on the surface I have doubts the PCM would like that. Even if it accepted the signal and the speedometer worked, the PCM seems to do some stuff with the idle based on being in motion, and I don't think the GPS would have the resolution.
You can, or at least I've seen it done by folks and we know how that goes. But, the parts to do the conversion to run a speedo are about 1/2 the cost of a used case.that makes me wonder if you could swap in a TJ output shaft and housing, or if there are other incompatibilities with the main case or internals that would prevent that.
That's a bargain. The last one I got cost me $5K. But then again, I got a whole Rubicon with it!I see them for 13-1700ish, a few a yr. Been starting to see JK rubii cases more often now too.
https://www.jeepforum.com/threads/jk-4-1-transfer-case-in-a-tj-yes-well-sort-of.3269393/that makes me wonder if you could swap in a TJ output shaft and housing, or if there are other incompatibilities with the main case or internals that would prevent that.
It was a pretty simple swap for a later models tj/lj in my experience. I wanted a little lower tcase ratio and a 241 popped up locally last year for $1400. I didn't want to spend that much but that is about what it would have cost to flip a 300 which I was also pricing out. My stock skid bolted up the same and I purchased an lj Rubicon driveshaft cheap on ebay. Cable shifter from savvy and a 4wd light switch and I was in business. It took longer to line up my bent up stock skidI'd like the low ratio but I'm not hardcore enough to need front digs or more than 2 speeds, I like a stock looking interior and everything to function as Jim Repp intended, and the effort as I understand it is comparatively small for a 241 swap.
i though some JK ran the 42rle still no? would that not bolt right up?https://www.jeepforum.com/threads/jk-4-1-transfer-case-in-a-tj-yes-well-sort-of.3269393/
This guy said he bought one that was rebuilt using a jk case. Granted there are no pictures and it is the internet. I think you just need the tj main shaft, tail housing and tone ring. Or maybe just the dakota digital GPS deal.
Plus it seems expensive to gather those parts.
