241 swap yoke questions
Southtowns27
Western NY
I picked up a 241 to swap into my LJ. I have a couple questions about the driveshaft yokes. The guys at Adam's Driveshaft say I can pull the yoke off my current SYE and it'll fit the 241. Can someone confirm this? The 241 currently has a 1330 yoke and I'd like to use my existing 1310 driveshaft. Does the 231 yoke fit the 241 or do I need a custom piece? If I do, where do I find it?
I am 99% sure that the yoke from your 231 will swap over to the 241. They should both be 32 splines.
The front is different though, your shaft is 27 spline, quick research shows that 32ZCV131-RUB from Tom Wood would help the conversion. I dont see it on his website though
Reactions: Southtowns27
Supposedly the 241 is prone to harmonic vibrations, which is why it came with a rear flange output with a harmonic balancer. That's something to consider if you are wanting to change to a yoke.
