just looking for advice/opinions about the rust on my 97 Wrangler tj. It’s really only underneath, not much at all on the body. I attached pics
X2 to that. The only thing that looks like more than mud or surface rust to me is the right side of the fuel tank skid and the body mount channel right around the mount in the 8th picture. I'd just clean up the fuel skid and paint it, and take a closer look at that body mount channel. If it's still structurally sound I'd just clean that up and paint it as well, if it's rotten enough to be a problem you can get patches for individual mounts or the whole torque box. I doubt you'd have any need for the full torque box based on how clean everything else is though.coming from a North Easterner, you are way ahead of the game compared to most here....it looks more like mud than rust.
X2. I bet if you took a wire wheel to all of the areas in those photos, you'd find very little serious rust. Folks in the rust belt would take that off of you in a heartbeat.I've seen far worse, that's not too bad.
Do what I do. Anytime I spot an area of rust (even if it's tiny), I take the wire wheel to it (either on my dremel or my much larger power tool) and strip it to bare metal, removing all the rust in that area. Then I degrease it and paint over it with a nice satin black paint with rust protection properties.
Works like a charm! Do that and keep up on it, and your TJ will outlive you!
Be careful using that. It's basically phosphoric acid and does work well neutralizing rust (I have a 64 F100 project that i've used it on). But if you paint afterwards, it has to be neutralized well. I think it's good for areas you cannot access with a wire brush and any type of paint. Sort of pour it in a crack kind of thing.
Thank you for all of your quick responses! This is my first Jeep and I bought it off of a guy for pretty cheap so I just wanted to get some expert opinions about it! Really loving all of the information in these forums and seeing all of the amazing Jeeps!
I wouldn't touch it to be honest. You would be money and time ahead to buy one from somewhere with little to no rust issues and ship it back to youBuying a project jeep, yes it's a Northeastern(the pics say so), would this be a waste of money? I have a buddy who can weld the frame crack, so that wouldn't be an issue
I'd address the axle seals and u-joints before even thinking about any rust issues on that TJ of yours. You'll want to clean up all that greasy gunk first anyway before doing any painting. Aside from that, as i'm replacing the suspension components on mine I've been using Eastwoods Rust Encapsulator, slightly thinned.. as I go along touching up everything underneath mine which looks (looked) very similar to yours.
Doesnt' look unsafe at all.. just everything under there looks original so i'd just take a closer look at the stuff producing all the grease buildup in those areas. My point was I think there are other areas to be concerned with before you worry about any rust issues.Super new to all of this so sorry if I sound stupid lol but just curious if there is something terribly wrong with the axle seals and u-joints? I don’t want to be driving it unsafely, that’s why I ask!
