I bought a fixer-upper high mileage 2001 TJ with a Dana 44 on the rear. It has a 4 inch lift and it seems the control arms are set up to rotate the axle so the driveshaft has a more or less straight shot at the t-case (so the pinion to driveshaft u-joint doesn't bind up). But this means the face of the pumpkin (as measured with the cover off) sits around 18 degrees off of vertical. Front Dana 30 looks to be similar. Is this going to cause any issues? Seems like in the front an extreme angle might mess up the steering since the knuckles will be rotated forwards - there's definitely some steering shaking at low speed, but I haven't diagnosed that yet. Also guessing that if this isn't the factory angle the oil fill level is probably way off too.
Also, I pulled out the Dana 44 carrier to check the condition of the bearings and discovered that there are no shims whastoever. Due to the angle of the pumpkin, once I unbolted the bearing caps, the carrier actually rolled right out of the pumpkin under it's own weight - no resistance at all. Am I right in assuming I should shim this up and reset the pattern? Bearings look OK, no chunks missing or anything, but feels a tiny bit rough to rotate. I was worried about them due to finding a lot of fine metal in the diff oil (was pretty old oil though) and then finding all sorts of gritty schmutz in the axle tube on one side. The backlash was 9 thou when I measured it but I didn't run a paint pattern on it.
