Seat wont move at all
Andrew520
Ontario
I have a 2001 jeep tj and have owned it for almost 2 years but have never been able to move my drivers seat. The seat wont slide along its track forward or backwards and the manual release for the tilt wont work also. I have tried to remove the seat but can only get the front two bolts out as the seat is blocking the rear two cant even fit my finger in there let alone a wench.
It sounds like there are cables in your seat that are broken or detached. Have you looked around with a flash light to see if you can visually see anything moving when you pull the levers?
No, what he is saying is that if your seat won't rock forward you cannot access the rear bolts. I have a similar problem. My seat slides but won't rock forward after my seat cover install. It is on my list...
Yes my problem is that it wont slide or tilt so i cant a
I looked around before making this post just to see if i could notice anything obvious but everything looked similar to my passanger seat which everything works on
There are parts under the seat which bend. Only answer is to remove the seat, 4 bolts, and bend the parts straight again. The bent pieces are real obvious.
Lubricants, rust busters will do zip. There is never any corrosion under the seat.
