What are your thoughts on changing all the fluids. Just bought a 2001 tj and am thinking change all fluids and start fresh as the new caretaker.
Redline MTL for your NV3550 transmission. Any good quality GL-5 is fine for your axles like a 75W-90, 80W-120, 80W-90, etc. The viscosity is not critical so long as it's a GL-5 gear lube. I prefer a conventional gear lube in my axles, the axle's ring & pinion gears run cooler with a conventional gear lube (yes). Castrol, Valvoline, Pennzoil, NAPA, etc. are all fine.2001 tj 60th. 4.0 manual. Federal land trails, hunting land two tracks. No hard off roads.
that's exactly the first thing I would do with any used vehicle.
best to start fresh
