Hi Everyone,
Recently got my 99 TJ. It has a 2” spring spacer lift and a 1” body lift. Looking to keep it relatively stock. Thinking about removing the body lift. After some research, it looks like PO didn’t adapt the transfer case lever bracket like I have seen in other body lifts with some kind of extension bracket. The fan and shroud also line up good. So, did PO raise the engine mounts? Other than those two concerns, it looks like it would be pretty easy to remove the body spacers and set it back on the factory ones that are still there. Advice and thoughts appreciated.
Thanks,
Chris
Thanks,
Chris
