Getting ready to change my front dif fluid on a 04 Rubicon. I have seen a couple of videos saying to use break cleaner to clean the dif before replacing the cover and filling. Is his good to go on a Rubicon locker? Advice appreciated!
ThisIt probably wouldn't hurt anything but I don't think I'd want to find out it melts the air line to the locker or anything.
If you're not having any problems and don't have a need to look inside, the 44 should have a drain plug on the bottom on the pinion side.
Yes, this is the plan. Praying for no shavings!Pull cover. Be sure all gasket material is scraped off housing and cover. Use a rag or paper towel to wipe out bottom of diff. Inspect rag for any metal shavings or bits. If it looks good then new gasket and reinstall cover. Fill.
If you find metal in the bottom of the diff then now is the time to get ready for a rebuild.
The brake cleaner is mainly for the mating surfaces. Clean them well, RTV gasket maker or new gasket. Should be good to go. You would likely know if something was wrong. Use towels to clean oil out of bottom as others suggested. Brake cleaner should be absolutely fine though.Thanks for the replies. Yes I would like to take a look inside since this is a new to me TJ. I also have an aftermarket dif cover that I may install. I think I will not use any break cleaner just drain, look, replace.
Do only the Rubicon D44s have the drain plug on the bottom? I have a rear Dana 44 from a '98 TJ and there is not a drain plug on the bottom only the fill plug on the cover.It probably wouldn't hurt anything but I don't think I'd want to find out it melts the air line to the locker or anything.
Some formulations of brake cleaner can definitely be fatal to rubber/neoprene. The real danger is that the hose can look fine afterward so you put the cover back on but start cracking and failing weeks later.It probably wouldn't hurt anything but I don't think I'd want to find out it melts the air line to the locker or anything.
There's a lot of good information on brake cleaners at https://en.wikipedia.org/wiki/Brake_cleaner including a warning that it can harm, often fatally, rubber and some plastics.My brake caliper assembly brake-cylinder boot is thin rubber material, it gets soaked a lot with brake cleaners. I have never seen it gets brittle in years.
Correct, only the rubis came with a drain plug at the bottom.Do only the Rubicon D44s have the drain plug on the bottom? I have a rear Dana 44 from a '98 TJ and there is not a drain plug on the bottom only the fill plug on the cover.
ThanksCorrect, only the rubis came with a drain plug at the bottom.
