T TustinSkyline New Member Joined May 1, 2021 Messages 2 Location 92705 Nov 3, 2021 #1 I can't figure out how to remove the front side marker lens assembly. I bought 2 ones and the old ones seem to be stuck in there permanently. Any suggestions?
K Ken Perkins TJ Enthusiast Supporting Member Joined Jun 23, 2017 Messages 176 Location Livermore, CA, United States Nov 3, 2021 #2 take the whole housing out from the back
C chimmike TJ Enthusiast Supporting Member Joined Sep 14, 2021 Messages 295 Location Sarasota, FL Nov 3, 2021 #3 the little cap on the bottom of the lens on the inside isn't really 'threaded' but unscrew it with a 10mm wrench.
hear Can't type Lifetime Supporting Member Joined Oct 18, 2020 Messages 3,510 Location Prosper, TX Nov 3, 2021 #4 Hit a doe doing about 65mph. Pops right out. Reactions: chimmike
OP T TustinSkyline New Member Joined May 1, 2021 Messages 2 Location 92705 Nov 3, 2021 #5 Problem solved - the prior owner had glued it in. It just needed a little persuasion. The new one was loose so I had to glue that in too!
