I went single DIN chassis with a floating screen from Joying. The 8.8” widescreen fits the TJ dash perfectly, and the CarPlay implementation works well.
I apologize... I didn't see your reply. I added these. Or one of them. It's mounted to the back of my steering wheel. Works great for volume and track control, and it's easy enough to operate entirely by touch.I really like that joying radio, I’ll have to check that out. How do you control the volume of that head unit? It doesn’t look like it has any physical controls
Here is the latest version of the one I have. Couldn't be happier with it... It's great.What model unit is this?
Does it also work with Apple CarPlay?
That looks great! What is it?I went single DIN chassis with a floating screen from Joying. The 8.8” widescreen fits the TJ dash perfectly, and the CarPlay implementation works well.
Is there anyway to hook up a variety of cameras to this? I'd like front and rear view, and also one underneath looking at the rear diff, and another that lets me see the passenger side front wheel
At night...And one for bird watching. LOL
You're likely going to need a composite video switch. While most head units will let you label each input, I haven't seen one with more than 2 video inputs. I bought an 8 port composite video switch I plan on wiring up once I get my rock cameras figured out.That looks great! What is it?
Interesting. Haven’t seen that before. Not a fan of automatic switching, but the manual switching via remote would work for my project. Thanks!You probably don't have audio to worry about, there are much cheaper solutions available, even automatic switches.
https://www.walmart.com/ip/Intelligent-Video-Switcher-4-to-1-Wireless-Car-Video-Switcher/215629346
Link is supposed to be "Intelligent-Video-Switcher-4-to-1-Wireless-Car-Video-Switcher" from walmart.
Just as a quick example, I'm sure there are plenty of video only switches of all types.
Did you need a special wiring harness or bezel to install that? Would you get the same one again? I'd like something similar, but with a thinner bezel and/or an external volume knobI went single DIN chassis with a floating screen from Joying. The 8.8” widescreen fits the TJ dash perfectly, and the CarPlay implementation works well.
