I have a 1999 TJ with half doors and 2 sliding glass windows. There are two latches, both glued to the inside glass that hook to a small metal hook screwed to the aluminum window frame. The latches are simple in design and L shaped with a single pin at the hinge to allow the latch to be lifted over the frame hook. The ends of the latches are broken and looking for someone that may have the inside parts from Steel Horse.
Any leads are appreciated, in contacting Best Top, they now only offer latches screwed through the glass.
Thank you, Darryl
Thank you, Darryl
