Slight play in NP241 transfer case input shaft
Sudo
Arizona
Any issues if there is slight play in the input to the transfer case at the front driveshaft? I can grab the front driveshaft and hear/feel slight movement. Not sure if this is normal. I dont believe it's the driveshaft.
Thoughts?
Rotational or up and down/side to side?
Up and down there is slight, very slight movement. I was originally thinking it was a driveshaft joint, but it looks/feels like it's the front output yoke that moves a bit.
if it's the yoke that the front driveshaft connects to, it's the front output shaft, not the input shaft.
I’ve always had a bit of play in my front output yoke. Though I also have persistent driveline vibrations from the front, so it may not be normal.
