I recently purchased a 2004 Jeep Wrangler Rubicon with 64,000 original miles. Jeep looks great but has definitely spent some time on the trail with previous owners. I have done a ton to it, including:
New rear chromoly axle shafts/bearings/seals (the original shafts had a slight amount of runout; front axle shafts are good)
New front passenger axle shaft U-Joint
New U-Joints on rear DS (had a slight "notchy" feeling on axle end of DS)
All fluids changed, including front/rear diffs and tc
New 32" Cooper Discoverer AT3 tires on stock wheels
New upper and lower ball joints on both sides
New front driver wheel hub/bearing
All new front suspension and steering rods/ball joints
Replaced 2" budget boost lift with 2" springs from BDS, plus a 1/2" spacer up front for leveling purposes
New Rancho shocks
New, longer sway bar end links
New sway bar bushings
Plus a hundred other things I'm probably forgetting. All of these were replaced due to wear, not as troubleshooting measures. My problem is, I'm having a very slight, tight vibration in the seat starting around 54 mps, up until around 60 or so, then it seems to fade somewhat. The vibration is there whether I am under load, or clutch is pressed in, or just coasting in neutral, while in that general speed range. For troubleshooting, I completely swapped the wheels and tires with a 2000 TJ that I have with the same tires (1" smaller, but otherwise same). The 2000 has no vibration issues, so I know the wheels and tires are good. The problem remained, even with these known good wheels and tires, so I put my others back on, and rotated them just for fun. The vibration is still present. Next, I removed the rear DS, and drove in 4 High... vibes went away, so it appears to be an issue at the rear of the Jeep. I checked runout on the output flange of the tc... it is running true. I checked for play at the pinion... it seems to be good and tight. I cleaned all of the yoke and flange mating surfaces to make sure there were no burs, dirt, etc... all good. I put the read DS back in, and the problem is still there. Driveline angles all seem to be ok, considering I only did a 2" lift. I did lower the tc with 1" worth of washers, but it didn't help. Pinion angle is 9, ds is 9, and tc is 8. Control arm bushings seem to be ok as far as I can tell. I'm kind of starting to run out of ideas... any thoughts? At this point I'm thinking all that is left that it could be is bad bearings in the TC at the rear output shaft, bad pinion bearing, bad carrier bearings, or DS out of balance.
Any thoughts would be very much appreciated. I have researched this for weeks and read more posts and articles on vibration than I can count. Thanks!
New Rancho shocks
