Those should work with TJ uppers. See the bend in the top of the lower door, and the bottom of the upper? The last picture of
@bobthetj03 with the doors on the jeep, the middle seam is what I am trying to point out. If you look at the first doors, they have a straight bar. Those were for the older CJ7, or early YJs, and how the top fit. After doing a little more self research, the red tag should have given away the original doors pictured are likely from a CJ based on when Bestop changed over to the yellow tag.
