Soundbar Dome Light Replacement and Cover Tip
alaskajohn
Gibsonia, PA
Hoping this helps others:
2001 TJ Soundbar Dome Light seems to be the same as 94-97 Dodge Ram Dome Light.
I was missing the dome light cover. On softtops, the dome light is in the sound bar. This is a different unit than the dome light that comes in the hardtops, and so searching online I was not finding any results ... only other that were people also looking for replacements.
However, I came across a note that seemed to suggest the dome light unit is the same that was installed in 1994 - 1997 Dodge Rams. I found one on ebay that came out of a 1995 Dodge Pickup and the photos looked like it might be the same... so I rolled the dice since it seemed worth the risk for $10.
When it arrived it was a perfect match, so I can confirm that at least for the 2001 Sahara, the lights are the same.
The part numbers on the bottom of the light are 56007264, SAE, 36033, and PA66.
Apologies if this is a duplicate thread, but I haven't found any other references to this cross-listed part.
-John
Awesome find! I see this question pop up regularly and sellers are always trying to get an arm and a leg for the “Jeep” covers.
Reactions: alaskajohn
I’m late to this conversation haha, but what lightbulb do you have in?
The 1995 Dodge Pickup and the 2001 Wrangler Dome light (aka Map Light, Courtesy Light) appear to be exactly the same. I've think I have the 912 bulb in it. They are pretty standard and most places should carry them.
Additional info on the original post, this dome casing was used in all of the following vehicles:
Dodge Ram 1500 3.9L V6 A/T REG CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 3.9L V6 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 1500 3.9L V6 M/T REG CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 3.9L V6 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 A/T CLUB CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 A/T REG CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 M/T CLUB CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 M/T REG CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 5.2L Magnum V8 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 1500 5.9L Magnum V8 A/T CLUB CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 5.9L Magnum V8 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 1500 5.9L Magnum V8 A/T REG CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 1500 5.9L Magnum V8 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 5.2L Magnum V8 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 5.2L Magnum V8 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 5.9L Magnum V8 A/T CLUB CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 2500 5.9L Magnum V8 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 2500 5.9L Magnum V8 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 5.9L Magnum V8 M/T CLUB CAB 6FT BOX 6.5 FT BOX1997
Dodge Ram 2500 5.9L Magnum V8 M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 2500 5.9L Magnum V8 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 5.9L Turbo I6 Diesel A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 2500 5.9L Turbo I6 Diesel A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 5.9L Turbo I6 Diesel M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 2500 5.9L Turbo I6 Diesel M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 8.0L Magnum V10 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 2500 8.0L Magnum V10 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 2500 8.0L Magnum V10 M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 2500 8.0L Magnum V10 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L Magnum V8 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 5.9L Magnum V8 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L Magnum V8 A/T REG CAB CHASSIS1997
Dodge Ram 3500 5.9L Magnum V8 M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 5.9L Magnum V8 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L Magnum V8 M/T REG CAB CHASSIS1997
Dodge Ram 3500 5.9L Turbo I6 Diesel A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 5.9L Turbo I6 Diesel A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L Turbo I6 Diesel A/T REG CAB CHASSIS1997
Dodge Ram 3500 5.9L Turbo I6 Diesel M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 5.9L Turbo I6 Diesel M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L Turbo I6 Diesel M/T REG CAB CHASSIS1997
Dodge Ram 3500 5.9L V8 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 5.9L V8 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L V8 A/T REG CAB CHASSIS1997
Dodge Ram 3500 5.9L V8 M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 5.9L V8 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 5.9L V8 M/T REG CAB CHASSIS1997
Dodge Ram 3500 8.0L Magnum V10 A/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 8.0L Magnum V10 A/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 8.0L Magnum V10 A/T REG CAB CHASSIS1997
Dodge Ram 3500 8.0L Magnum V10 M/T CLUB CAB 8FT BOX 8FT BOX1997
Dodge Ram 3500 8.0L Magnum V10 M/T REG CAB 8FT BOX 8 FT BOX1997
Dodge Ram 3500 8.0L Magnum V10 M/T REG CAB CHASSIS1997
Jeep Wrangler 2.5L Power Tech I4 A/T BASE1997, 1998, 1999
Jeep Wrangler 2.5L Power Tech I4 A/T SE2000, 2001, 2002
Jeep Wrangler 2.5L Power Tech I4 M/T BASE1997, 1998, 1999
Jeep Wrangler 2.5L Power Tech I4 M/T SE2000, 2001, 2002
Jeep Wrangler 4.0L Power Tech I6 A/T BASE1997, 1998, 1999, 2002
Jeep Wrangler 4.0L Power Tech I6 A/T SAHARA2000, 2001, 2002
Jeep Wrangler 4.0L Power Tech I6 A/T SPORT2000, 2001, 2002
Jeep Wrangler 4.0L Power Tech I6 A/T X2002
Jeep Wrangler 4.0L Power Tech I6 M/T BASE1997, 1998, 1999
Jeep Wrangler 4.0L Power Tech I6 M/T SAHARA2000, 2001, 2002
Jeep Wrangler 4.0L Power Tech I6 M/T SPORT2000, 2001, 2002
Jeep Wrangler 4.0L Power Tech I6 M/T X2002
