I replaced the stock dash gauges with a Holley Pro digital dash in my 2006 TJ. I noticed after this that the dome lights in the soundbar will not come on when you open the door, or when you turn the switch on the handle on the steering column. I checked fuses and relays several times, then I thought to plug the wire harnesses from the stock gauge cluster back into the stock gauges, and they worked again. Apparently the wiring for the soundbar lights runs thru these harnesses. Can someone tell me which wires to splice together, or what to do to bypass the stock setup and get the soundbar lights working? Thanks.
