Find other things that are actually important to be OCD about.![]()
It’s important to the OP.
Is it a small thing, yes but it matters to someone. I don’t care if my Speedo is off but it annoys the f out of if my bolts/bolt heads don’t match.
To each their own.
If you tweak the actual signal to correct the speedo then your actual speed will be off. You’ll need to pull the cluster, pluck the needle off and set it to where you feel it’s correct.
