Have a 99 tj with rear 2003 dana 44 non disk. Have been battling seal leaks and even worse since re gearing. Have done drivers side 3 times and now both sides having issues. Chromeolly axles are straight and no obvious damage to be seen but still leaking even after detailed cleaning and instaling spot on. Differential is leaned back due to lift and SYE placement but don't think overfilled with lube as no foaming or blow-by out of vent (vent is not plugged) Can someone pass along a part number for a speedy seal if you have gone down this frustrating path witn success.
Thank you in advance
